Noisy wiper motor!
  • TA22GT
Replied by TA22GT on topic Noisy wiper motor!
Posted 10 months 2 weeks ago #218671
Learning as I bumble along.
I adjusted the play in the spindle with the cover off. Then put the cover back and tried it.
It was still noisy but quieter..as soon as I backed out the plastic grub screw a quarter turn the screech came back.
Backing it out lets the spindle wobble.
Just something you might try if you have a noisy motor as it is quick and easy.
Replied by Notanumber on topic Noisy wiper motor!
Posted 10 months 2 weeks ago #218672
Has that also stopped the noise ?
Replied by Airportable on topic Noisy wiper motor!
Posted 10 months 2 weeks ago #218675
There are different connectors on more recent motors & if you have one & require the other an element of grafting is required.
A while ago I did an an analysis of this & it will still be there way back in time. I'm sure, with a modicum of detective work you will be able to find it.
That 40 odd quid is probably a sensible buy, a bench rebuild has a better outcome than footleing under the bonnet.
  • TA22GT
Posted 10 months 2 weeks ago #218678
Not as in a cure but much less noisy.
What threw me was having to turn the wipers on in a downpour to be greeted with a loud shriek. It was ok the last time I used them at least not alarming.
As soon asIback out the grubscrew the shriek comes back!
  • TA22GT
Posted 10 months 2 weeks ago #218679
I agree AP..and if I mess it up its not the end of the world.
Replied by David Aiketgate on topic Noisy wiper motor!
Posted 10 months 2 weeks ago #218682
The freelander motor will NOT work in our cars!
It looks the same, BUT:-
One uses switched earth, the other switched live.
As an exercise I did finally get it to work, But you will need to disassemble the pcb from the motor in the freelander motor and totally isolate it from the motor body. Otherwise the motor body becomes live and blows fuses instantly.
Last Edit:10 months 2 weeks ago by David Aiketgate
Last edit: 10 months 2 weeks ago by David Aiketgate.
The following user(s) said Thank You: mowog73, TA22GT
Posted 10 months 2 weeks ago #218683
That reminds me of the fun I had getting an MGF wiper stalk to work with an MGB wiper motor (on an MGB). Though both were negative earth cars the switching was on the wrong polarity. I breifly mused on isolating the body of the wiper motor from the car but it was much easier to just change the + and - feeds in to the stalk switch as a dead easy workaround. The same workaround could be used on an F/ TF to be able to use a Freelander wiper motor but you'd just also need to make a change to the washer pump feed.
Replied by judiths handyman on topic Noisy wiper motor!
Posted 10 months 2 weeks ago #218684
There is a complete assembly from seller coopersteve1 on ebay for £41.24 if you fancy bench stripping refurbing etc.
Thank you. That might not be a bad idea. My motor is in great condition apart from what seems to be a bearing and that won't be expensive.
if I practice on a s/h one I should be able to keep my original motor!
And sell one of them at a handsome margin on ebay when complete.
Posted 10 months 2 weeks ago #218694
As a rule a squawk from a motor is indicative of dry bearings. I’m officiating, with my wife in my local park, child watching, specific children, not children in general; just to clarify.
The top bearing is a race, I think & the bottom is oilite & it is this that grumble to the point of insurrection, I’ll dig my spare out, when I get home & have a poke about.
  • TA22GT
Posted 10 months 2 weeks ago #218702
Thanks AP I appreciate it.
I've sprayed lithium grease through the hole where the plastic grub screw goes. Was hoping it would find a way in to the bearing or oilite. I know it's not the correct grease.
Tightening that grubscrew has reduced the noise so I am thinking it is the bearing at the top but I am guessing.
If you do have time to fiddle about I would be very interested in learning more.
Posted 10 months 2 weeks ago #218706
  It looks like both bearing seem to be oilite & so both have the capacity to dance about, groaning in the process.
I mentioned the two types of connector earlier, one is square & the other a truncated triangle, the pin out correlations I can’t help you with at the moment.
  • TA22GT
Posted 10 months 2 weeks ago #218708
Thank you.
The screech did sound like a bearing noise but it has eased a bit after taking play out of the spindle.
It's still not acceptable and needs sorting.
Time to create page: 0.512 seconds
